JMR5859's avatar
JMR5859
orbi Router not broadcasting signal
Orbi Mini Router RBR40 Not Broadcasting Signal
Orbi Mini Router RBR40 is no longer broadcasting signal -- unsure as to the cause.
The only light that turns on when I plug in the power is the green power light – the ring for indicating the router's health does not emit any light.  Unfortunately I had registered my product shortly after purchase and so I no longer have support; I have also just recently passed my 1 year hardware warranty (December 2, 2018 was the end of hardware warranty).
Troubleshooting done:
  • Unplug and replug in to power
  • Press and hold "Reset" button for 1 minute (in hopes of factory reset)
  • Press "Sync" button for 1 minute
  • Plugging in ethernet cord directly from laptop (Macbook Pro on macOS 10.13.6 High Sierra): the laptop does not recognize the router at all (from Network Preferences it indicates that there is nothing plugged in)
  • About the only other thing you can try is another power supply.
    • JMR5859's avatar
      JMR5859
      Switched power supply with the one from satellite.  Same issue. The light on the back is green but no lights on top, no signal broadcast.
      • FURRYe38's avatar
        Seems that your RBR needs to be replaced. :smileyembarrassed:
