Meloncharlie's avatar
Meloncharlie
Orbi Router not issuing IP addresses, but Satellites do
Hi everyone -    I would appreciate anyone's help as I'm starting to pull my hair out.   I have an Orbi RBR50 System that includes the Router and 2 sattelites in my home.  Basically, at the core ...
  • Meloncharlie's avatar
    Meloncharlie
    Aug 12, 2017
    Update:  All 3 ports now issuing 192 addresses.
    I had turned off DHCP and turned it back on, then rebooted the router and that seemed to do the trick.  Not sure if that's all that was needed, but it does seem to be working now.
    Thanks everyone!
