Meloncharlie
Aug 12, 2017Aspirant
Orbi Router not issuing IP addresses, but Satellites do
Hi everyone - I would appreciate anyone's help as I'm starting to pull my hair out. I have an Orbi RBR50 System that includes the Router and 2 sattelites in my home. Basically, at the core ...
- Aug 12, 2017
Update: All 3 ports now issuing 192 addresses.
I had turned off DHCP and turned it back on, then rebooted the router and that seemed to do the trick. Not sure if that's all that was needed, but it does seem to be working now.
Thanks everyone!
peteytesting
Aug 12, 2017Hero
with the orbi router issue is it all 3 ethernet ports that dont work ?
and are you using the default dhcp subnet range , eg 192.168.1.1 for the lan ip address and the dhcp from 192.168.1.2 to 192.168.1.254
also check if ipv6 is disabled
Meloncharlie
Thanks everyone!
