jrw1881
Mar 25, 2021Guide
orbi router not recognized
Recently did a factory reset because router kept dropping connection and reconnecting mostly on its own? Had this problem on an off for several weeks, hense the factory reset. Now when booted up...
CrimpOn
Mar 25, 2021Guru - Experienced User
jrw1881 wrote:Now when booted up the router flashes white and never gets to blue or connect. It stops on solid white andf never shows up in orbi app.?? Now when trying to connect through phone app it says "orbi not found"? So I am totally without internet except on one old computer wired directly to out Ariss 6141 roouter?
The phone will need to be connected to the Orbi WiFi before the Orbi "app" will find it. When the Orbi router powers up, the WiFi SSID printed on the product label (bottom) should appear as one of the available WiFi networks. Password will be what is printed on the product label. Does this not happen?
Oh yeah if this thing is dead as a router does anyone think it can be saved to be used as a satellite? (not very hopefull)
There is a hack (on the internet) to transform an Orbi router into a satellite. It is not supported by Netgear and I have never attempted to use it (or even look closely at it).
- jrw1881Mar 25, 2021Guide
Yes The the wifi shows my orb router but no connection. I know my wifi ssid and password but i cannot sign in.
The thing just stays on solid white??
Thanks will look into hack if this thing turns out to be a "brick".
