Daru
Dec 17, 2019Aspirant
ORBI Router password
I have an extremely strong password on my Orbi network, likely unhackable. Does that protect my router as well as my network? Therefor, how important is my route password?
Dec 17, 2019Guru - Experienced User
Do you mean the SSID PW or the RBR web page log in PW? The SSID PW only protects the wifi form being accessed by unauthorized users to connect to the wifi. The log in page PW only protects the RBRs web page from being accessed by unauthorized users.
Daru
RBR means Router Loging? Is the router login as vunerable as my wifi net twork? Is it outside my WiFi network? To clarifi again, Is my router protected by my SSID password?
- FURRYe38Dec 17, 2019Guru - Experienced User
RBR means the model of the Orbi router. RBS is the Orbi Satellite.
Only if you have remote access enabled could someone attempt to log in from a remote location. However, thats over an HTTPS connection so much less chance of someone getting in. If you don't need any remote access from a remote location, you can keep remote management disabled. When remote managment is disabled, the RBRs web page is only accessible from the LAN or wireless side of the network, meaning from with in your home.
I use a plain simple 8 character PW for the Admin log in web page. I keep this to myself. So nobody can get in to the RBRs web page to change anything. The SSID PW is similar. Though I don't see a need for anything complex and risk with in my neighborhood is very low and I know all my nieghbors. Of course this doesn't mean this fits all. Users need to pick what is best for them.
the PW on the SSID only protects the WiFi signal from being access from unauthorized connectsions, from out side the home or inside the home. So give the this SSID password to only those whom you allow to connect to the SSID name.
