Foxeslink
Nov 08, 2023Aspirant
Orbi Router RB50 and Wifi mesh
Hello,
If I buy for instance NETGEAR - WiFi 6 mesh AX1600 will I make it work with the rbr50's? Like have the same ssid and changes to the best one? wifi roaming?
1 Reply
No. There are specific models of Orbi satellite that work with specific Orbi routers. Netgear published this table:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
None of the WiFi6 satellites are compatible with the 802.11ac (WiFi5) Orbi systems.
