timcrane
Jul 08, 2021Follower
Orbi router RBR 40
I am trying to hook up some YI cameras in the house. Can’t connect unless 2.4 g. Someone else set up the mesh and I can’t get past the security questions to change settings. Help!
Jul 09, 2021Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Contact the mfr of these cameras for help and information regarding there product.
