cataran
Apr 10, 2020Follower
Orbi Router RBR20 - dual band device priority
I just installed a Bosch BCC50 wifi thermostat. I have an Orbi RBR20 dual band router, and using an iPhone XS max and the Bosch app to set up the thermostat. The thermostat setup is requiring my app to be on a device in the 2.4GHz band, but Orbi automatically has my iphone in the 5GHz band. Can I temporarily move my phone to the 2.4GHz band?
1 Reply
- tomschmidtVirtuoso
Try this method which works for most IoT devices that require your smart phone to also be on the 2.4GHz frequency to configure their WiFi.
1. Launch a web browser from a computer or mobile device that is connected to the Orbi network.
2. Enter orbilogin.com or 192.168.1.1 (IP address of your router's LAN port).
3. The login window opens, enter username "admin" and the password that you configured for your router.
4. Click Advanced tab > Advanced Setup > Wireless Settings.
5. Uncheck the box "Broadcast SSID" for the 5GHz frequency and click Apply to save the settings.
6. Confirm that your smartphone is connected to the 2.4GHz frequency. If it is still connected to the 5GHz frequency, then "Forget" the WiFi network for your SSID, then reconnect to it and enter your SSID password. Now your smartphone should be on the 2.4GHz frequency.
7. Try connecting your IoT device to the Orbi network per its setup instructions.
8. If it works, re-enable the broadcast SSID option for the 5GHz frequency.
9. On your smartphone, turn WiFi off and back on again and it should reconnect to the strongest signal.
10. If your smartphone did not reconnect to the 5GHz frequency, then "Forget" the WiFi network again for your SSID, then reconnect to it and enter your SSID password.If this fixes your issue, then please mark this as resolved.
