bohdanf
May 06, 2024Aspirant
Orbi router RBR20 - how do I access a PC on home network while away from home
Hi, I apologise if this is a topic that has been asked before, I cannot find it, if so. I have a Mesh WiFi setup, an RBR20 router, with two RBS20 satellite units. I have connected a small (8-port...
May 06, 2024Guru - Experienced User
I usually just user team viewer to remote log into one of my severs. and if I need to access the router, i teamviewer into the server and use its (the servers) browser to access it
bohdanf
Hi there, thanks for the reply. This is not quite the solution I was after but I will check this further, if there are no other easier options.
