DavidO11
Feb 06, 2020Tutor
Orbi Router rbr20 ethernet port not detecting device
Orbi RBR20 does not detect a device connected via the ethernet port. The device is an alarm system using DHCP. Any advice gratefully received. David.
Feb 06, 2020Guru - Experienced User
Try a different port.
Swap LAN cables between device and RBR. Use good quality CAT6 LAN cables.
Install a non managed, non green ethernet Gb LAN switch behind the RBR and connect your devices to the switch.
