jolson490
Jan 12, 2021Aspirant
Orbi router RBR20 intermittent connectivity issues
Last April from Best Buy I purchased a new Orbi AC2200 - the box says RBK20W, and it includes an RBR20 router and an RBW30 satellite. It's worked mostly ok til about a month ago I started occassional...
- Jan 19, 2021
Glad the ISP took care of the problem.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
vajim
Jan 12, 2021Master
jolson490
vajim: The problem started about a month ago. The bullets in my "I've tried the following things" list are things I tried yesterday. So the problem occurred with both firmware versions.
FURRYe38:
* My modem says Spectrum on it, the model is ET2251, and it also says "Docsis 3.1 eMTA" on it.
* Please correct me if I'm wrong, but I don't believe the feet/distance matters because I've unplugged the satellite.
* The screenshot I'm attaching shows the wifi networks near my laptop.
* I have not yet tried a factory reset on my RBR20 (but I can/will if that's what you recommend).
- FURRYe38Jan 12, 2021Guru - Experienced User
I would try a reset and setup from scratch.
- vajimJan 12, 2021Master
jolson490 wrote:vajim: The problem started about a month ago. The bullets in my "I've tried the following things" list are things I tried yesterday. So the problem occurred with both firmware versions.
FURRYe38:
* I have not yet tried a factory reset on my RBR20 (but I can/will if that's what you recommend).The reason I ask is normally networks don't go a foul on their own. Something happened, power surge, user error, etc.
I always ask when was the last time it worked ok? What changed?
- jolson490Jan 13, 2021Aspirant
Thank you everyone for the helpful suggestions.
I decided to call Spectrum again yesterday. When I called them the other week they thought the new modem would fix the issue. But when I called them yeseterday they ran a test and they are still seeing an intermittent loss of signal between them and my new modem. So they're sending a tech out this upcoming Sunday to fix whatever wiring issue is present. I'm a little surprised because my house is only 20 years old and nothing should've happened or changed in the last month or so that could've caused a wiring issue, but I guess anything is possible. I'll add a reply here to let everyone know how it turns out - I'm hoping after the tech comes that then my Orbi will be able to work reliably.
- FURRYe38Jan 13, 2021Guru - Experienced User
Sounds like this is an ISP issue. Let us know how it goes after the tech comes. Have him test things while he's there to be sure. Make sure speeds are to spec with out the Orbi attached and with Orbi attached to the new modem.
jolson490 wrote:Thank you everyone for the helpful suggestions.
