JeffL85
Jul 17, 2020Follower
ORBI Router RBR20 work in Germany
All, Let me begin with stating I am not tech savy!! I recently moved to Germany and I am trying to get my ORBI RBR20 up an running and it is not connecting to the router.I have updated the fi...
Jul 17, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance?: If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
JeffL85 wrote:All,
I recently moved to Germany and I am trying to get my ORBI RBR20 up an running and it is not connecting to the router.I have updated the firmware to no avail. Please help! Im a chasing a white rabbit or is it user error?
