DLT_ST
May 14, 2020Aspirant
ORBI Router RBR20
Interesting how my free support plan ran out on 1/27/20 and days later my HVAC system can no longer connect to the router. I've tried everything I can think of but the system will not accept the pass...
May 19, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
DLT_ST wrote:Interesting how my free support plan ran out on 1/27/20 and days later my HVAC system can no longer connect to the router. I've tried everything I can think of but the system will not accept the password. I've reset the psswd and still does not accept. Netgear wants to charge me for support? Coincidence?? Anyone have any advice?
