kes_vas
Aug 07, 2020Follower
Orbi Router RBR20
Hi ,We have RBR20 Router and 2qty RBS , some of the location we can't get wifi signal.so we need to add RBS 20 in additional.
How many RBS we can Add in this Router?
1 Reply
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
