Cloygirl
Aug 03, 2019Aspirant
Orbi router RBR40
I have an ORBI RBR40 router in my home office in the front of my house and need to extend WiFi to inside my detached garage in the back of the property (about 90 feet through exterior walls). I have...
- Aug 03, 2019
Sometimes finding the optimal location for WiFi equipment is complicated. Obviously, a location where the satellite will not connect to the router at all is unacceptable. The Orbi 5G wifi backhaul signal is affected by whatever is in the path between router and satellite. Things like refrigerators, AC ductwork, brick walls, heavy furniture, metal garage doors, windows with metallic film, etc. impact the signal. I had a WiFi router located on the side of brick chimney (because it looked "ugly" on the front mantle) and half the house got lousy coverage. Moved the router to the front, and now "voila!"
2.4G signals penetrate much better than 5G, so the Ring doorbell camera has an advantage there. It could be that moving the satellite and/or camera just a little bit might improve the signal enough to make it successful.
ekhalil
Aug 03, 2019Master
Will the Satellite be installed in-house or outdoor?
If outdoor, then the only outdoor Satellite is the RBS50Y.
Otherwise there are plenty of other Satellite models that you can select from for indoor use.
- CloygirlAug 03, 2019Aspirant
It will be used indoors. The information I've read on Orbi satellites states that they must be relatively near to the router. I have one satellite in the middle of my little house (about 25 ft. away). Thanks for your help!
- ekhalilAug 03, 2019MasterIt’s recommended to have the Satellite between 30 to 70 ft from the Router.
