Andyswindon's avatar
Andyswindon
Follower
Oct 25, 2019
Orbi router RBR50 - 4S257350004F7
I have installed Orbi router onto my sky network as well as an Orbi satelite that came with the package.
my devices are saying they are connected to Orbi when i look in wi fi setting of mobile phone etc.
However i often experience hanging on websites and this is often resolved when i turn the satelite off. Also when i log into my orbi account it says i am not connected to orbi.
1 Reply
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
