Brad21
Jun 14, 2020Aspirant
Orbi Router (RBR50) & 1-Satellite (RBS50) Download Speeds
Orbi Satellite is connected with ethernet cable to Orbi router. Satellite provides service in remote part of house. Cable internet service provider says signal good to modem. Speed check for each:...
Jun 15, 2020Guru - Experienced User
Be sure your wifi device is connected to the RBS and not the RBR. Turn OFF the devices wifi radio for 5 seconds then back when near the RBS. Then speed test.
Brad21 wrote:Orbi Satellite is connected with ethernet cable to Orbi router. Satellite provides service in remote part of house. Cable internet service provider says signal good to modem. Speed check for each: router 240, satellite 94 download & 6 upload for both (these are consistent over several speed tests). The speed for router and satellite are as above regardless whether connected using wifi or ethernet cable.
Is the drop in satellite download speed normal?
Thank you.
- Brad21Jun 16, 2020Aspirant
FURRYe38:
Thank you for your response. I will start working on getting answers to your questions and see if I can make some improvements.
