n19htmare's avatar
n19htmare
Orbi router [RBR50] and 2 Orbi satellites [RBS50] in a Daisy chain limits?
Dear Netgear,
How many satellites can you Daisey chain. Currently I have two and am wondering if the following scenarios are possible:
a- buy one extra RBS50 and have Router > sat 1 > sat 2 > sat 3.
b- buy one extra RBS50 and have Router > sat 1 > sat 2  AND  Router > sat 1 > sat 3.
c- buy two extra RBS50s and have router Router > sat 1 > sat 2 AND Router > sat 2 > sat 3.
Has anyone any experience of this configuration?
Kind regards,
Tristan
1 Reply
  • plemans's avatar
    The wireless backhaul allows many possibilities. But each jump in the node is going to add some latency. If its possible, here's how I'd do it.
    Sat 1<------sat2<--------Router---------->sat3---------->sat4
    This would only be a single hope, daisy chain setup. Sat 1/4 still get a little extra latency but not bad. Kind of a combination daisy chain/star configuration.
    I've never ran more than router------sat1------sat2 setup because my home isn't large enough to need another satellite at the end and its worked well.
