SJern03
Mar 22, 2020Aspirant
Orbi Router RBR50 No Longer Communicating.
I have an Orbi RBR50, with 3 RBS50 satellites. The system has been working fine, since I purchased it until this past week, when it began dropping the WiFi and blocking the internet (yes, internet w...
Mar 23, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
SJern03 wrote:I have an Orbi RBR50, with 3 RBS50 satellites. The system has been working fine, since I purchased it until this past week, when it began dropping the WiFi and blocking the internet (yes, internet works fine). It would reset and work if I powered off the router and rebooted it. Today, it will not reboot and will not connect with the satelittes. The router will either pulse white, or stop and glow white. The Salellites are all pulsing purple. Has anyone had this issue and is there a resolution other than buying a new router.
In advance, thank you for your time and input.
Steve Jernigan
sjernigan3@me.com
