MeBeAngel
Jul 20, 2021Aspirant
Orbi Router RBR50 throttled download Speed
Hey all, hope you can help because I,ve been trying to trouble shoot this for days.. I have an Orbi RBR50 router / Firmware v2.7.2.104 Connected are two PCs running windows 10 home, a laptop ...
MeBeAngel
Are both desktop and laptop connected to the Orbi the same eay for the test?
i.e, both wired or both WiFi?
Yes all tests were done identically.
Please explain "Download". (I assume it means using a web browser to get files from an internet source).
The old internet service was FIOS and the new internet service is ???
Both have similar speeds?
Downloading any files, content or updates. It doesnt matter what I try to download. When I downloaded updates for my drivers, it was at 3Mbps. when I downloaded test files through google chrome, it was at 3Mbps. When I tried to download an update for a game through steam, it was at 2Mbps. It doesn't matter the source. My laptop can download from all those same sources in seconds.
Unfortunately I'm not sure, I dont pay for the service here. I do know that it's around 1Gig speed.
My FIOS was 1Gig as well.
MeBeAngel
A test example
- MeBeAngelJul 20, 2021Aspirant
Speed test from Orbi Unit
- CrimpOnJul 20, 2021Guru - Experienced User
Thanks for the screen shots.
So, both computers are connected over WiFi for these tests (not ethernet).
One shows a Link Rate of 866.7 (the maximum possible on Orbi at 802.11ac ).
The other computer shows what Link Rate?
Orbi's built-in SpeedTest by Ookla records an internet download speed of 453.
What does SpeedTest report when run on the two Windows computers.
This appears to be similar to one computer being connected to WiFi at 802.11ac and the other connected at 802.11b (the oldest and slowest speed). That's the reason for asking about the Link rate and the SpeedTest from each computer.
This screen shot is the speedTest from my Desktop. The other SpeedTest above is also from my desktop. I cant get to my laptop at the moment. The tests I took earlier with my laptop were pretty much the same though. The only difference is that my laptop is downloading files just fine. I even connected my desktop directly to the modem through ethernet cable and it STILL wont download files faster than 3Mbps.I'm seriously stumped.
