Orbiuser22
Nov 29, 2022Follower
Orbi Router RBR50 won’t connect to the internet
Hi
My Orbi router won’t connect to the internet. I’ve tried the setup process numerous times and followed the instructions precisely. The Orbi is detected and all cables are connected, or so the Orbi app tells me. The process always ultimately fails. My modem’s internet works without the Orbi.
Please help me if you can. Thanks in advance.
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Does the RBRs web page show the status using a PC and web browser connected to the RBR at 192.168.1.1?
