TomShap
Sep 26, 2020Follower
Orbi router rbr50
I have rbr50 router with satellite that came with it. I need to add another Satellite that has an ethernet port (as I plug my voip phone into it) Bought RBK13 at Sams club this morning (which is a ...
Sep 26, 2020Guru - Experienced User
The 1 series is not supported for use with the other Orbi models. The 1 series is only a dual band system.
Youll need to find a RBS20, RBS30, RBS40v, RBS50 or EX7500, 7700 or 8000 series units to add ot your Orbi 50 series if you think you need additional wifi coverage.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
