genivos
Sep 18, 2021Aspirant
Orbi router RBR50v2 WOL through VPN
Hello, I've succesfully setup a VPN on the Orbi. My PC works with WOL inside the network (Windows 10), it wakes up after shutdown no problem. Now I want this to work through a VPN. However, state...
- Sep 19, 2021
CrimpOn wrote:Synology NAS appears to be able to generate WOL magic packets:
https://www.nextofwindows.com/how-to-wake-up-windows-machine-via-wol-from-synology-nas
I have a QNAP but there's as well a solution for that:
https://forum.qnap.com/viewtopic.php?t=130500
Somebody made an app which you can launch from the NAS. I've tested it, works fine as expected. This is a good solution for me as I just need to be able to wake my NUC at home when I need it. Also it doesn't have to be a WOL package from the phone. Trigerred from my laptop though the NAS app makes even more sense cause I want to take over my NUC's screen anyways from the laptop.
Thanks for the insight! Once you mentioned server I was directly thinking about a NAS app.
Gazza43
How did you manage this, please? The NETGEAR help desk told me that they did not allow third party software on their devices - I was looking at using Express VPN.
- CrimpOnSep 18, 2021Guru - Experienced User
The original post states that he is using the built-in OpenVPN host feature. That allows devices outside the LAN to connect to the Orbi LAN through a secure VPN connection. Stock Orbi firmware does not support using the Orbi as a VPN client (for devices inside the LAN to connect to internet resources through a VPN connection). There is third party firmware for the RBR50 model (only that model) which supports two different VPN clients on the Orbi router (OpenVPN and WireGuard).
- Gazza43Sep 18, 2021Aspirant
Okay. Thanks for that. Bit more complicated than I anticipated and more technical than my limited expertise. Looks like I will have to try and find another solution; ie, buy another router.
Many of the VPN services provide a license for up to 5 computers at one time. I am not convinced that it is all that necessary to have every device in the home using a VPN connection. But, if that is the goal, then some other router is the way to go.
