Billo56
Sep 17, 2021Aspirant
Orbi router RBR50v2
I am having an issue being blocked when using an app on my phone which I've been using with this Orbi router all year!?? When I tried getting on the app it blocked it as unencrypted content....blah b...
CrimpOn
Sep 17, 2021Guru - Experienced User
Just as a first impression, there appear to be two issues here:
- An attempt to use a web browser with a specific web site has been blocked. This could be because (a) the web browser now rejects attempts to browse to "http" web sites (which are not encrypted) instead of https web sites(which are encrypted), or (b) this Orbi has the Bitdefender Armor product activated which is somehow blocking this web site. If this is (a) the browser, then there is usually an option (in very small type) to ignore the warning and proceed to the web site.
- Accessing the Orbi web interface. When the Orbin admin password is entered incorrectly three times, the Orbi brings up a web page titled "Password Recovery". During the original setup, the user was supposed to be asked to select two 'security questions' which can be used to reset the admin password if the user can no longer enter it correctly. Alas, either this doesn't happen or some users rush past this page without selecting questions and entering answers. In this case, the only way to gain access to the Orbi web interface is to perform a Factory Reset, which will restore the Orbi web interface to "admin" and "password" (and also reset the WiFi credentials to those printed on the product label.)
Perhaps I misunderstand the situation.....?
Billo56
Sep 20, 2021Aspirant
Thank you for your insight into this. I will probably do the factory reset and hope that it works. I do have the Bitdefender Armor set up on my Orbi...
