DougB628
Mar 11, 2019Apprentice
Orbi Router reset to factory defaults, lost my entire configuration!
I was experiencing some problems with slow wifi (speed test under QoS was showing accurate available speed 200+ down, 20+ up), Apple TV was getting highly variable speed as low as 5Mb up to maybe 30M...
raven_au
Mar 11, 2019Virtuoso
DougB628 wrote:
Has anyone else ever had a "random" factory reset?
Yes, but it only happened to me once a very long time ago.
- CrimpOnMar 11, 2019Guru - Experienced User
This sounds alarming. So, exactly how was this restart accomplished? Unplugged the power and then plugged it back in again? Used the "Reboot" option on the "Advanced->Home page"?
- JestasApr 16, 2019Aspirant
It just happened to us today. Do we need to go through an entire setup again? This is a huge issue, resetting all connected devices in THEIR apps - Sonos stereo systems being the biggest issue.
- FURRYe38Apr 16, 2019Guru - Experienced User
You might try a re-load of the v44 FW files using IE11 or FF browser, factory reset and setup from scratch.
Also someone did a 30-30-30 reset as well which seems to have solved this problem on there system.Be sure when you get the system back up and running completely, do a back up of the config to file on the RBR for safe keeping.
- michaelkenwardApr 16, 2019Guru - Experienced User
Not just "someone". Several people have reported that this works.
Better yet, they have saved and restored their settings and they stick without resurrecting the bug.
No harm in trying it.
If it does work for you, please report back so that we can add it to the repertoire of solved issues.
