DougB628
Mar 11, 2019Apprentice
Orbi Router reset to factory defaults, lost my entire configuration!
I was experiencing some problems with slow wifi (speed test under QoS was showing accurate available speed 200+ down, 20+ up), Apple TV was getting highly variable speed as low as 5Mb up to maybe 30M...
raven_au
Mar 11, 2019Virtuoso
DougB628 wrote:
Has anyone else ever had a "random" factory reset?
Yes, but it only happened to me once a very long time ago.
CrimpOn
Mar 11, 2019Guru - Experienced User
This sounds alarming. So, exactly how was this restart accomplished? Unplugged the power and then plugged it back in again? Used the "Reboot" option on the "Advanced->Home page"?
