DougB628
Mar 11, 2019Apprentice
Orbi Router reset to factory defaults, lost my entire configuration!
I was experiencing some problems with slow wifi (speed test under QoS was showing accurate available speed 200+ down, 20+ up), Apple TV was getting highly variable speed as low as 5Mb up to maybe 30M...
Apr 06, 2019Guru - Experienced User
You might try a re-load of the v44 FW files using IE11 or FF browser, factory reset and setup from scratch.
Also someone did a 30-30-30 reset as well which seems to have solved this problem on there system.
