DougB628
Mar 11, 2019Apprentice
Orbi Router reset to factory defaults, lost my entire configuration!
I was experiencing some problems with slow wifi (speed test under QoS was showing accurate available speed 200+ down, 20+ up), Apple TV was getting highly variable speed as low as 5Mb up to maybe 30M...
cibola
Apr 16, 2019Aspirant
Yes. I'm on the latest firmware before anyone asks. It will stay up for a minute or 2 minutes the spontaneously reset to factory. No solution yet.
- FURRYe38Apr 16, 2019Guru - Experienced User
You might try a re-load of the v44 FW files using IE11 or FF browser, factory reset and setup from scratch.
Also someone did a 30-30-30 reset as well which seems to have solved this problem on there system.
