rudyPHX
Sep 05, 2021Aspirant
orbi router restarts several times a day with firmware 2.7.3.22
with the firmware update 2.7.3.22, my orbi router restarts several times a day. it only started happening with 2.7.3.22. i manually downgraded to 2.7.2.104, and that worked like a champ, but it automatically updated again. i have referenced online instructions, but the orbi admin site that i'm using (orbilogin.com) does not have an option to turn off automatic firmware updates like the instructions indicate. hopefully someone can help me. thanks!
Can't be turned off. If you have a upstream router for firewall, can be blocked there.
- rudyPHXAspirant
also, i tried factory resetting first, and that didn't work. when i downgraded the firmware that fixed it completely, i'm just hoping someone can help me turn off auto-update for the firmware, until a new version is available and hopefully not problematic for me. thanks!
- rudyPHXAspirant
ouch. okay. man that's too bad. thanks.
- Haysuz5Aspirant
I have been having the exact problem since the new firmware update...how do you downgrade the firmware to the previous version?
rudyPHX wrote:also, i tried factory resetting first, and that didn't work. when i downgraded the firmware that fixed it completely, i'm just hoping someone can help me turn off auto-update for the firmware, until a new version is available and hopefully not problematic for me. thanks!
Just load the FW file from NG download page using same process to upgrade FW files:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
- ScottWayAspirant
Could anyone tell me the solution to this or was one never really found? I will admit I do not know what Voxel is.
