rudyPHX
Sep 05, 2021Aspirant
orbi router restarts several times a day with firmware 2.7.3.22
with the firmware update 2.7.3.22, my orbi router restarts several times a day. it only started happening with 2.7.3.22. i manually downgraded to 2.7.2.104, and that worked like a champ, but it autom...
- Sep 05, 2021
Can't be turned off. If you have a upstream router for firewall, can be blocked there.
Sep 05, 2021Guru - Experienced User
rudyPHX
ouch. okay. man that's too bad. thanks.
- FURRYe38Sep 05, 2021Guru - Experienced User
đ
- rudyPHXSep 21, 2021Aspirant
any idea how often netgear pushes a firmware update? this is getting really rough (having the router restart itself 2-4 times a day). i'm kind of hoping that a new firmware update fixes this problem for me. thanks!
- FURRYe38Sep 21, 2021Guru - Experienced User
No. NG doesn't announce when new FW is forth coming.
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
