rudyPHX
Sep 05, 2021Aspirant
orbi router restarts several times a day with firmware 2.7.3.22
with the firmware update 2.7.3.22, my orbi router restarts several times a day. it only started happening with 2.7.3.22. i manually downgraded to 2.7.2.104, and that worked like a champ, but it autom...
- Sep 05, 2021
Can't be turned off. If you have a upstream router for firewall, can be blocked there.
ScottWay
Sep 27, 2021Aspirant
Could anyone tell me the solution to this or was one never really found? I will admit I do not know what Voxel is.
- rudyPHXSep 27, 2021Aspirant
as far as i can tell, it was not resolved. i literally purchaed a new wifi router (TP link). so frustrating, but i just couldn't work with the unreliable connection any longer.
- ScottWaySep 27, 2021Aspirant
I agree. This just started a few weeks ago. It's pretty maddening. Thanks for the response.
- FURRYe38Sep 27, 2021Guru - Experienced User
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
