stevefxp
Sep 21, 2018Apprentice
Orbi Router Showing LAN Port at 100 Meg
Hello all,
I am new to the Orbi world, having just purchased a router and satellite. I like what I see so far but have a few questions.
Port 1 on the LAN switch of my Orbi router will only show connected at 100M. I have the satellite wired ethernet connection there. When I move it to Port 2 it shows as 1000M. Has anyone seen this? Second with the satellite connected via a wired ethernet backhaul I would expect the wireless backhaul to turn off but it is still operating. How do I turn off the wireless backhaul?
Thanks,
Steve
Sort By
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration.Be sure the Lan cable is of good quality. Swap lan cables to test. Cat 6 recommended.
If you can't seem to get 1000Mb on the port, possible the port could be bad. Try testing with different ethernet PC to see if problem follows.
- stevefxpApprentice
Its a bad port on the router, so I have to open a ticket for its replacement.
Can you, or anyone else, answer the second part of the question. I am wired ethernet connected between the router and the satellite. It sounds like it will use this connection for the ethernet backhaul, yet I am still seeing the wireless backhaul trading packets in the statistics page. Is there a way to turn off the wireless backhaul, as I would prefer to use that bandwidth(1733) for normal wireless communications.
