BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
BartCH
Jan 07, 2017Tutor
Small addition: I just checked the Advanced settings of the router. In the LAN port sections it says the WAN port is down (0 packets). My orbi router is in Access Point mode however and has received an IP address from my cable box. Also the orbi wifi internet connection works fine, so there is traffic going between the cable box and the orbi WAN port. Recently introduced sofware bug? Until a few days ago the ring light used to go off, as in 'working normally'.
r3v1l0
Jan 08, 2017Initiate
I am having the same issues. I am using it in AP mode.
I tried going back to 1.4.0.18 but made no difference. System seems to work ok, but annoying magenta ring glowing away!
Your LAN & WAN settings should be greyed out when in AP mode, mine are.
- DarrenMJan 09, 2017Sr. NETGEAR Moderator
Hello r3v1I0
Have you tried on .34 version I have seen some reports of the issue being fixed on the latest firmware.
DarrenM
- r3v1l0Jan 09, 2017Initiate
Hi DarrenM,
Thanks for the response. I first noticed it after the .34 upgrade, which is why I went back to .18... I am back on .34 now...
UPDATE: I moved the ethernet cable from my Asus router to the Orbi router (in AP mode) from LAN1 to WAN and I no longer have the magenta led ring...
- bbroygbivJan 16, 2017Initiate
I have the same problem. Also in AP mode and also with .34
I tried the solution of moving the LAN cable to the WAN connection, and it indeed extinguished the light. But it also killed the throughput.
- Retired_MemberApr 17, 2018
Evidently this problem has been going on for some time. So,,,WHAT"S THE FIX??
- Kris_ChenJun 29, 2018Tutor
It's never fixed !!
My situtaiton is the same as what all you guys talking about: If you leave WAN port alone and just connect LAN port, the light of solid magent
keep showing there. If WAN&LAN port are connected by cable, it's vanished and become normally.
