BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
r3v1l0
Jan 08, 2017Initiate
I am having the same issues. I am using it in AP mode.
I tried going back to 1.4.0.18 but made no difference. System seems to work ok, but annoying magenta ring glowing away!
Your LAN & WAN settings should be greyed out when in AP mode, mine are.
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello r3v1I0
Have you tried on .34 version I have seen some reports of the issue being fixed on the latest firmware.
DarrenM
