BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
Kris_Chen
May 24, 2017Tutor
I have the same issue as what forum is discussing with. My Router is turned solid magenta but 2 of my satellites are ok(i.e. light was tunred off after blue color)
I just updated firmware to V1.10.1.2. Operation mode is AP.
All coummication between router and satellites even mobile devices are ok. Just color is not right.
How to fix it ?
- DarrenMMay 26, 2017Sr. NETGEAR Moderator
Hello Kris_Chen
Have you tried to resync those units? might just need a power reset.
DarrenM
- Kris_ChenMay 26, 2017Tutor
Thanks for your response.
Well, even I power off router/satellites and then power on all units to sync again. The color of Solid magenta is still in the router itself. Useless.
Is this issue coming from firmware ? Wondering ...
- DarrenMMay 30, 2017Sr. NETGEAR Moderator
Hello ClintoKL
No way to stop the firmware updates they are automatic.
Kris_chen
Are the units still working just a issue with the lights? If so could be a bug in the firmware on AP mode I will have to report that issue.
DarrenM
