BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
DarrenM
May 26, 2017Sr. NETGEAR Moderator
Hello Kris_Chen
Have you tried to resync those units? might just need a power reset.
DarrenM
Kris_Chen
May 26, 2017Tutor
Thanks for your response.
Well, even I power off router/satellites and then power on all units to sync again. The color of Solid magenta is still in the router itself. Useless.
Is this issue coming from firmware ? Wondering ...
