BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
Silent_Forest
Jul 03, 2017Star
Running latest firmware 1.11.0.20. (July 2017). Similar issue to others in this thread. The system was running well for several weeks running Orbi as an access point (AP). Then, a solid Magenta light appears on the router but NOT satellite. Satellite is reachable via web interface but router (base station unit) is not reachable via the web interface. The base station also will not respond to pings. Read many of the messages posted here. Rebooted unit and network modem. Magenta light persists. Strangely entire wifi function still working well. Finally, I try one last thing. I had assigned a fixed IP address to the Orbi base station but NOT the Orbi satellite on my network modem/router. I removed the fixed IP address and allowed the Orbi base station to acquire IP via DHCP. The problem appears solved. It seems with this current firmware version, Orbi base station does not like having a fixed IP address assigned to it and running as an access point (AP)
