BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
PrezWRC
Jul 16, 2017Tutor
I today updated from 1.11.0.20 to firmware version 1.12.0.18 and since then also have a solid magenta ring on my RBR50 and no more access to the UI system (via browser nor Genie app). I'm running the system (router and satellite) on AP mode and besides the constant solid magenta ring and no Ui access the system is working fine and fast. Does anyone have a solution available? Thanks!
