BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
ClintoKL
May 26, 2017Apprentice
I rebooted just the router and havent had the magenta light come back on the router as yet. I didnt re-synch the satellite.
Darren, is there a way to stop automatic updates of the firmware? I have everything running ok. It was a delicate balancing act but Im happy on my system to stop right where I am.
Amazon Alexa is not dropping off. My LIFX bulbs are effectively staying on the system, I have had a bulb drop off but no worse than my old router. I have full 100Mb internet to the three areas I want them at (Home Office, Home Theatre Room and Living Room).
Like i say, its a delicate balancing act but its working. I dont want to stuff up things with firmware updates that might work for someone elses set up but not mine.
GDMACK
Oct 20, 2017Star
I have the same problem: My Router is in AP mode, is working fine (strong WiFi Signal), but the light is solid magenta. The satellite is solid white. How do I make the solid magenta light go out? I have the latest firmware installed. No problems on the system, but don't think the ring light should be solid magenta.
