BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
GDMACK
Oct 20, 2017Star
I have the same problem: My Router is in AP mode, is working fine (strong WiFi Signal), but the light is solid magenta. The satellite is solid white. How do I make the solid magenta light go out? I have the latest firmware installed. No problems on the system, but don't think the ring light should be solid magenta.
DESIi1
Nov 05, 2017Star
I too have the solid Magenta on the router with the latest firmware. It the system has also been very unreliable, so much so I also turned on my Comcast WiFi to act as a backup.
In AP Mode where should the cable box be plugged into - The WAN or LAN ports?
What is Netgear's response to why the Magenta is on solid when that is not mentioned in the literature?
