BartCH
Jan 07, 2017Tutor
Orbi router solid magenta (not the satellite)
My Orbi router (not the satellite) stays solid magenta after rebooting. When I login to the router, every parameter looks OK. The router is in Access Point mode and has received an IP address from my...
Apr 15, 2018Guru - Experienced User
Have seen other post that the use of the LAN port works better for AP mode. I would suggest trying both to see. Yes, the WAN port will show Magenta LED if it's not connected. I've tired this on mine. LAN port works fine.
