MX348
Aug 20, 2019Aspirant
Orbi Router stops working after @ 3 hrs, Flashing Green Halo
Hi All, I purchased a used Orbi RBR50 Router from eBay. I installed it and a rsatellite and everthing was rock solid for the first 4 days. Now for whatever reason, everthing stops working after...
Aug 20, 2019Guru - Experienced User
You might disconnect the WAN port cable from the ISP modem on the RBR and watch the top ring led and see what appears. It should be PINK when the WAN cable is disconnected from the modem.
