MX348
Aug 20, 2019Aspirant
Orbi Router stops working after @ 3 hrs, Flashing Green Halo
Hi All, I purchased a used Orbi RBR50 Router from eBay. I installed it and a rsatellite and everthing was rock solid for the first 4 days. Now for whatever reason, everthing stops working after...
Aug 20, 2019Guru - Experienced User
Have you tried a full factory reset on the RBS and RBR and setup from scratch after loading FW?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
MX348 wrote:Hi All,
Now for whatever reason, everthing stops working after @ 3hrs.
Oddly the router is flashing a Green LED light ring after this occours.
After looking through all the docs online, I cannot find a reference to the Green LED Halo.
The only fix is to shut down and restart everthing.
I am running the latest V2.3.5.30 FW for my devices.
As a last resort, I have disable all the auto upgrade features via telnet and downgraded the devices to V2.2.1.212 to see if i can reach stability again.
What is the cause of a green led halo ?
Thanks
MX348
Aug 21, 2019Aspirant
Hello,
Thank you for the responce.
I have performed a full factory reset 3x now hoping that would solve the issue, however no luck.
I am using a TP-Link DOCSIS 3.0 Cable Modem model number TC-7610 with Comcast internet service.
I am using the orbi in router mode.
Additionally, I have downgraded the FW of both the Router and Satelite to version 2.2.1.212 and disabled auto upgrade via telnet on both devices.
Running 2.2.1.212 actual makes the issue happen faster like 30mins.
When the device quits, i can no longer even ping the router hardwired into it from my desktop system.
The halo is deffinatly green, and I have verified the magenta color when i remove the inter connection.
- FURRYe38Aug 21, 2019Guru - Experienced User
Sounds like your Orbi system is faulty and needs to be replaced. I recommend opening a support ticket and ask about an RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
MX348 wrote:Hello,
