AdrianRod
Jul 24, 2017Aspirant
Orbi router suddenly lighting majenta
My router suddenly lit up majenta. I have tried disconnecting and restarting but still lighting up majenta. Other things are plugged into my router (AT&T Uverse) ethernet connections and they are wor...
DarrenM
Jul 26, 2017Sr. NETGEAR Moderator
Hello Adrianrod
You should have it connected to the WAN port when connecting it to your modem also do you have your ATT modem bridged or if not do you have orbi set to AP mode?
DarrenM
- AdrianRodJul 26, 2017Aspirant
Yes, I have it plugged into one of the local ethernet ports. Not sure about it being bridged. Its been about 6 months since I originally set it up. I had a power outage a couple weeks ago and it hasnt come back since.
- DarrenMJul 26, 2017Sr. NETGEAR Moderator
If the power knocked it out you may want to contact support if the unit is under warranty.
http://www.netgear.com/support/
DarrenM
