aorlikoff
Jul 20, 2018Aspirant
Orbi router to CenturyLink
Double NAT issue. I want to fix by using centurylink as modem in transparent bridge mode. However when I change that in the settings I lose the internet.
Jul 23, 2018Guru - Experienced User
You might try AP mode then see if Guest Network is still available in the menu....
