Jilllett
Feb 23, 2021Aspirant
Orbi router with another network but same house
We have the orbi RBK13 hooked up to our satellite internet and it works great. Our internet is amazing. We have another internet service (satellite out where i live can be crappy and it caps out at 10...
CrimpOn
Feb 23, 2021Guru - Experienced User
Jilllett wrote:
We have the orbi RBK13 hooked up to our satellite internet and it works great. Our internet is amazing. We have another internet service (satellite out where i live can be crappy and it caps out at 100mbs) can i buy another system a d hook it up to my other internet connection? I’m not the most savvy internet person so I’m not sure. TIA
Yes, you could. Two systems creates a coordination issue. Every device will be connected to either one or the other. If one is interrupted, all of those devices lost internet until they are switched to the other WiFi system. When it comes back on, they remain on the other system until manually switched back.
It might be worth looking into a product that connects to two ISP connections and feeds both of them to the Orbi. (and less costly, too.)
For example, the Ubiquiti Edgerouter X (https://www.ui.com/edgemax/edgerouter-x/ ) sells for $59 (Amazon is higher, possibly because of free shipping https://www.amazon.com/Ubiquiti-EdgeRouter-Advanced-Gigabit-Ethernet/dp/B00YFJT29C/ref=sr_1_3?crid=3JR3WGIJ2SY76&dchild=1&keywords=edgerouter+x&qid=1614105669&sprefix=edgerouter+x%2Caps%2C221&sr=8-3
Page 71 of the User Manual explains how to connect the Edgerouter to two (or more) internet connections and then connect the combined feeds to the local LAN (which would be the Orbi router).
Using a product such as this would leave you with a single mesh WiFi network, higher total capacity, and automatic "fail over" if one of the ISP connections is interrupted.
- vajimFeb 23, 2021Master
CrimpOn wrote:
Jilllett wrote:
We have the orbi RBK13 hooked up to our satellite internet and it works great. Our internet is amazing. We have another internet service (satellite out where i live can be crappy and it caps out at 100mbs) can i buy another system a d hook it up to my other internet connection? I’m not the most savvy internet person so I’m not sure. TIAYes, you could. Two systems creates a coordination issue. Every device will be connected to either one or the other.
Perhaps, but this is the issue I wasn't sure about from the original post. Is he/she planning on running both networks at the same time or use one as a backup?
- JilllettFeb 23, 2021AspirantSo we have our satellite internet that my daughter mostly uses for zoom classes. We use it as well for work or whatnot. But after we hit 100 mbps or whatever it slows down.
So we have internet that’s not satellite as well. It’s not as fast as our satellite so we only use it when needed. So we set up the orbi on the main internet and i was thinking of purchasing another one to use on our backup internet. I hope this makes sense lol- vajimFeb 23, 2021Master
So we have internet that’s not satellite as well. It’s not as fast as our satellite so we only use it when needed. So we set up the orbi on the main internet and i was thinking of purchasing another one to use on our backup internet. I hope this makes sense lolYes...it should work, however as CrimpOn mentioned the device management may be a nighmare from the stand point you won't have any control over what device connects to what network unless you use separate passwords for each router. Not something the average user thinks about.
Interesting setup. If you do go with, please let us know how it comes along.
