Old-fart
Oct 06, 2018Tutor
Orbi router with satellite and then add a modem
Hello everyone,
my name is Greg, I'm 87 years old and brand new to your community. My wife (of 68 years) and I are not techy so need your help.
We had a CM500 Netgear modem and a Asus RT...
Oct 06, 2018Guru - Experienced User
I recommend a Arris SB6183 or Motorola MB7420. You can find these on amazon or walmart sometimes. Bestbuy or Frys if you have these local stores.
I would recommend the RBK40 series just one base router and satellie. Your home size is fairly average and no need to 3 wireless APs. I believe just a router and maybe 1 satellite is needed. If you want just a router, I recommend a NG R7800
Old-fart
Oct 06, 2018Tutor
Sorry for late response.
Thank you for your suggestions. We were planning on the 2 pack Orbi, mini router and satellite. Because it is tri band and speedy, should we get a really fast modem for when we decide to up our plan with Cableone. As long time customers, they always send out offers. We've always ignored but with newer system all around, maybe time to upgrade.
I saw many Motorola modems on Amazon. Lots of Arris and Netgear too.
What do we want to look for from a modem? Cable one said we should get Docsis 3 or 3.1
- FURRYe38Oct 07, 2018Guru - Experienced User
What is your ISP speed you pay for UP and Down? The Arris SB6182 or Motorola MB7420 are DOCSIS 3.0 and will handle up to 600Mb on the DOWN. ALso check to see what your ISP supports. Most ISP do support these modems.
- Old-fartOct 07, 2018Tutor
What are your thoughts on the CM 600. One of our neighbors said we should ask you when we were at church breakfast this morning.
I haven't used the 600. I have a CM1000/Arris 6183 and Motorola MB7420 and works well.
The main thing is to keep with a broadcom based chipset modem. There are some modems that are intel based that currently have problems:
Again also check with your ISP to see that they officially support.
We have the power plan 200 and 6.
