ldgornaz's avatar
ldgornaz
Follower
Apr 27, 2020
Orbi Router with Satellites
How do you add extra ethernet ports to the Orbi base?
1 Reply
  • FURRYe38's avatar
    install a NetGears GS series Gb LAN switch behing the RBR. The come in 5, 8, 16 port or more versions.
    Non managed and non green eithernet switches are commended if your connecting the RBS to the RBR thru a switch.
    Managed switches can be used, however all IGMP protcols and green ethernet features needs to be disabled on managed switches.
