rosaliajensen's avatar
Mar 31, 2021
Orbi router won't connect to modem only existing router
Im stil pretty new to all this and have been trying to connect over new orbi router and satelite for hours, i feel like i have tried everything and it just wont connect to our modem, in the app it sa...
  • CrimpOn's avatar
    Mar 31, 2021
    rosaliajensen wrote:
    So really the question is what difference it makes whether the router is connected to the modem or the existing router? Is there a big difference in efficiency?
    No. There is no measurable difference in efficiency.  Thousands of customers have done the same thing.
    You should be aware that there are specific activities that will fail when there are "two routers".  Search for "Double NAT" or see Netgear's explanation. https://kb.netgear.com/30186/What-is-Double-NAT
    My Orbi functioned fine for two years when connected to my ISP router.  Then I wanted to activate OpenDNS, which cannot function behind two routers and got Spectrum to switch me to a "plain modem".
