mjgolfer
Nov 21, 2022Follower
Orbi routerRBR20 - forgot answers to admin questions
Need to change the orbi router to an access point but can’t log in since I forgot the answers to the admin questions. How do I reset the questions
Unless you have set up password recovery, and provided answers to the set of questions that comes up, you are sunk. Try using it and you can get sucked into a closed loop because there aren't answers that the router can check against those you supply.
This is the only way out.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
